NK Road Exhaust Bracket - Favour Needed?
servetakid
Hi,
I have a Nk road exhaust with a standard stub... And I've been a twonk and while working on the scooter I've managed to loose part of the chancase bracket. :oops:
The bit I've lost is the bit that joins the end can to the chaincase bracket, with the slots cut into it so you can alter the angle. I would really appreciate it if some one with one of these exhausts could send me the dimensions so I can have one made up, or if any one has a spare that thy would be willing to part with. :)
Cheers,
carlos fandango
Is it the flat piece with a hole and a slot ? I'll measure mine tonight for you and let you know.
Russ
Speed Demon
You'd probably be better to phone AF and ask if they can sell you one. Steve who makes the pipes will have made loads so it shouldn't be impossible to source a spare.
Get to SULK
servetakid
I have contacted them and they wanted 40 quid for it :o I think this was for the whole chaincase bracket, but I wasn't sure....
so I was going to get a friend to knock one up...
And yes it is the flat piece, russ. Thanks
Speed Demon
:shock: Fair enough!
Get to SULK
carlos fandango
I Decided to go home for lunch :) so here you are, i forgot to write on, its 5mm thick
Russ
carlos fandango wrote:I Decided to go home for lunch :) so here you are, i forgot to write on, its 5mm thick
Russ
Well done Russ saved me a job when i got home ;)
servetakid
Thanks, I've given the measurements to a friend and he will make me one up. Cheers once again.
THE DADDY
How good is the nk road on performance, got a monza 240 with jl3 on at moment but fancy a change. :?
servetakid
I'm very happy with it my self, though I've not got a whole lot to compare it with. It got good reasults in the scootering review, however I think the franspeed pipe is the flavour of the month :P
