Page 1 of 2
bgm supercharged dampers
Posted: Mon Jun 18, 2012 8:50 pm
by col68
I have just fitted my new bgm dampers i only have 27mm of the chrome shaft showing and they are bottoming out when i braking, they are set on the hardest setting . when they are fully out off the bike there is 48 mm showing . bike has got standard springs in the forks . the brackets are welded on the fork legs at 23.5cm as it says in the sticky book . bike is an s2 li with ts1 and disc brake fitted . what do you think . :? :? :?: :?:
Posted: Mon Jun 18, 2012 9:13 pm
by soulsurfer
I think we need a picture...
Re: bgm supercharged dampers
Posted: Mon Jun 18, 2012 9:34 pm
by col68
dont know how to put pics on . took them off bike at mo don't want to break off mountings top or bottom !! got cleethropes rally at weekend . want to get a solution before i refit them .
Posted: Mon Jun 18, 2012 9:51 pm
by CPH Lambretta
I had exactly the same problem with mine.
I built my GP when the first edition of Stickys book was out.
I noticed he changed things regarding damper bracket positioning for the second edition.
Posted: Mon Jun 18, 2012 9:59 pm
by col68
what is the measurement in the new book ?
Posted: Tue Jun 19, 2012 2:31 am
by Minority
If it's an outboard disc, convert to antidive, problem solved. Most people who have done the conversion reckon it's fantstic.
Posted: Tue Jun 19, 2012 7:43 am
by coaster
Minority wrote:If it's an outboard disc, convert to antidive, problem solved. Most people who have done the conversion reckon it's fantstic.
That won't stop them bottoming out on bumps, only on braking
Posted: Tue Jun 19, 2012 8:25 am
by Minority
OP only complained about bottoming out on braking, but your right of course, it won't make any difference to bumps ;)
Posted: Tue Jun 19, 2012 9:43 pm
by jason frost
Remove the bottom buffers and fit the smaller type, should give abit more room.
Posted: Wed Jun 20, 2012 7:44 am
by col68
thanks for the help new sticky book says set them at 23.5cm-24.5cm and smaller buffers will put it right. I think i may change springs to . ta col
