A bit more Sil tuning ~ courtesy of mick abbey
Posted: Mon Jun 18, 2012 5:01 pm
by mnpes
66.00mm ~ 58/107 ~ Fast road tune ~ Added finger ports ~ Asso piston
Barrel topped 1.30mm ~ 9.1 compression ~ Squish 1.20mm
Engine set-up ~ Modified mikuni tm28ss powerjet ~ Mb flowed manifold ~Modified jl3 with rg 250 endcan ~ Madspeed clutch ~ Iwis chain ~ li150 innocenti box ~ 46t solid innocenti crownwheel with modified bush ~ innocenti front drive
Very torquey ~ Responsive & not thirsty ;)
Re: A bit more Sil tuning ~ courtesy of mick abbey
Posted: Mon Jun 18, 2012 5:30 pm
by Spanish Fly
Interesting port layout. :o
Does activity = achievement? :?
SF
Posted: Mon Jun 18, 2012 5:57 pm
by mnpes
Spanish Fly wrote:Interesting port layout. :o
SF
Was my same thought ~ When I fitted the barrel ~ A LOT OF ACTIVITY
Does spit-back @ low-revs ~ But not over-much
Mick Abbey"s work ~ Road n Track speak for his 2 stroke tuning QUALITY
I will get round to having the set-up dynoed ~ But decked the scooter @ easter
THANK - YOU FOR THAT ~ Mr.No Licence
Posted: Mon Jun 18, 2012 11:25 pm
by MADSPEEDRB260
Looking good mate well done...
Posted: Tue Jun 19, 2012 11:06 am
by lockman69
There’s a lot of work gone into it, I would be very interested to know how it runs...I am running a standard Indian stage 4, 30mm Dellorto &JL3 and that pulls 70mph and is a total joy to ride.
Posted: Tue Jun 19, 2012 1:36 pm
by ove
I`m running the scooterotica 150cc that mick Abbey tuned as a test run. I`m running it with a cheapo 57.6mm piston 1.5mm rings,28mm pbhb open mouth,jl3, Li150 gearbox 46x15.
It pulls really well in 1st 3 gears,can ring the nuts off it in 3rd and it`ll do 55mph(gps) and I`ve had 70mph(gps,as speedo only goes to 60!) in 4th with a slight backwind.
So looking at your set up mnpes and the fact its a 200cc you should see very good results.
Had it dyno`d with Dan and it was kicking out around 12bhp which is more than some 200`s. I then sent barrel back to mick for more work,I`ve had it dyno`d again but my stator plate decided to come loose and fcuk it up(foookin gutted i was) :oops: :oops: I`ve now done 4000 miles on it so it is also very reliable,apart from my bolting above said stator down enough.
Don`t ask me about port timings you`ll have to give mick a call,but be warned the man can talk for England.
cheers ove.
