Gearbox Mashed Up. Use Vijay Super MK2 as Replacement?
Posted: Mon Jun 18, 2012 12:38 pm
Hello
Took my engine apart as the clutch was playing up.
The gear cluster is destroyed where it runs in the needle bearing and the needle bearing has been smashed into dozens of little unidentifiable pieces. The ball bearing in the endplate is obviously well sh@gged too after having a wobbly clutch and gear cluster.
The gearbox is / was an Italian GP200 and I'm using a 46T clutch sprocket and a 19T drive sprocket which gives the ratios to suit the motor. I doubt I will be able to get hold of a decent Italian GP200 Christmas tree for less than 5 million pounds so I need an alternative. Now lurking in me shed is a complete gear box (4 x loose gears, the gear cluster and a 15T drive sprocket) from a Vijay Super MK2.
In standard form (46/15) the ratios are a bit different in 1st, 2nd and 3rd to what my GP200 with 46/19 gives me but the 4th gear ratio is pretty well bang on the same.
Anyone know of any reasons not to use this gearbox? The name is great so it must be good.
Not sure why the needle bearing and cluster ate themselves. Think once they start to go and the hardened surface has worn through it's all over pretty quickly.
Any help, advice or words of wisdom gratefully received. I'd like to be riding again asap.
Cheers.
Cheers.
