Mugello 200 28phbh jetting help.
Posted: Fri Jun 15, 2012 9:38 am
by scoot gp
Bought a 28phbh to replace my 25phbh, will be runing a standard mugello 200, clubman pipe and a 28phbh with a ram air filter.
Does anyone have the same setup and could point me in the right direction for jetting please?
Re: Mugello 200 28phbh jetting help.
Posted: Fri Jun 15, 2012 11:24 am
by jonnyb
You could try the jetting that I use on my 30mm Mugello V4 200 as a starting point, it should be a tad rich which wouldnt be a bad thing?
AV264 X13 second from top clip 45 slide 120 main 53 pilot.
I'm sure someone who has the same setup as you will be along soon
Posted: Sat Jun 16, 2012 7:40 am
by scoot gp
Thanks, it's only so I can get it running somewere neat before getting dyno'd
Posted: Sat Jun 16, 2012 7:45 am
by Special X
jonnyb wrote:You could try the jetting that I use on my 30mm Mugello V4 200 as a starting point, it should be a tad rich which wouldnt be a bad thing?
Take the main to 115 and you'l be in the ballpark for a PHBH 28.
Posted: Sun Jun 17, 2012 11:25 pm
by mickdale
hello jonnyb
can you tell me what filter you use if at all?
cheers
mick
