Page 1 of 9
Cutdown ....work in progress
Posted: Wed Jun 13, 2012 4:47 pm
by Fenian Mick
Re: Cutdown ....work in progress
Posted: Wed Jun 13, 2012 7:30 pm
by maskie66
enjoyed pics and looking good. not sure about back end though. not for me but its not mine and thats what makes em all different
keep pics coming though
will
Posted: Wed Jun 13, 2012 8:23 pm
by CANbus
Good work Fenian Mick, I like it, what setup are you running?
Can I recommend that you weld on a security loop, IMO when a lammy is taken down to this level it should be standard practice these days.
Posted: Wed Jun 13, 2012 9:00 pm
by maskie66
security loop a good call. note to self for my cutdown!!
Posted: Wed Jun 13, 2012 9:06 pm
by tomdavid1988
f@@k yeah! my kind of scooter, look forward to seeing it progress
Posted: Wed Jun 13, 2012 9:11 pm
by RICSPEED
Great ... Been hanging out for a cutdown
Posted: Wed Jun 13, 2012 11:24 pm
by Fenian Mick
CANbus wrote:Good work Fenian Mick, I like it, what setup are you running?
Thanks for the comments and good point about the security loop.
Did the engine about 18 months ago and the frame mods about 12 months ago and only getting time now to start again.
the engine is a TS230 race tour, with Broady piston and alpha crank, Also old type 6 plate Broady clutch with packer but using hydraulic set up and a inside the hub hydraulic disc brake.
I had gearbox and other transmission parts cryogenically frozen and gears and piston coated in a molybdenum dry lube.
the forks using outboard shockers and converting the links was tricky getting it all lined up.
shortened fork tube and forks
I keep doing the dry builds then changing my mind
Posted: Wed Jun 13, 2012 11:59 pm
by gpts1
Looks Great!
Posted: Thu Jun 14, 2012 7:58 am
by dopeshots
Looks sweet! Question about the rear disc, is that a mod u have done or is it available to buy? I've never seen this type of rear disc before, how does the rear wheel go on? Any chance of some more images of it please.
Cheers and keep up the good work :fb:
Posted: Thu Jun 14, 2012 8:37 am
by mick1
very nice........what did you do on the 2nd day of the build ?
