rubber for exhaust bracket
Posted: Mon Jun 11, 2012 1:32 pm
by fred
Hello all,the rubber washers that fit between my expansion chamber(nk),and crankcase bracket have fallen apart. What alternatives could i use? I was thinking of grinding some jl bushes down.
cheers,fred
Re: rubber for exhaust bracket
Posted: Tue Jun 12, 2012 6:52 pm
by DMC
fred wrote:Hello all,the rubber washers that fit between my expansion chamber(nk),and crankcase bracket have fallen apart. What alternatives could i use? I was thinking of grinding some jl bushes down.
cheers,fred
you got a photo of what you need Fred? or where it needs to fit.
Posted: Tue Jun 12, 2012 7:41 pm
by fred
It's where the expansion bolts to the crankcase side bracket, with the 2 m8 bolts. I've ordered some nylon bar. I'll cut it to size and drill it. Can't find heat resistant rubber.
How's it going dug?
Posted: Tue Jun 12, 2012 8:16 pm
by DMC
Not bad Fred,i'm still p1551ing about with engines.
The reason i asked for a photo is I had a NK on my Suzuki 225 for years and the original swan neck spacers fell to bits the morning of a rally and the only thing I had in the shed that was rubber was an inner tube. So I cut out two pieces that matched the swan neck profile and they were on up till last year when I put the RB engine in.
The exhaust never cracked or came loose so might be worth a look if your stuck mate
