Small frame Xmas tree turning blue when heated
Posted: Sun Jun 10, 2012 12:17 pm
Ok I know it probably wasn't the best idea but I was removing a old bearing from my xmas tree by first gently cutting away the outer race and bearing track with a Dremmel. I then decided that I would cut a small slot in the inner race and heat it up then tap it off. Anyway... went a bit mad with the heat and the bottom set of gear teeth turned blue . Now I know when you harded iron you heat it until blue then dows it in water, then heat it again blah,blah... but have I softened the metal and made the xmas tree weaker?
