T5 mk1 hydraulic disc set up
mad-bry
Looking at the possibility of fitting a hydraulic disc brake to a MK1 (squaretail) T5.
Has anyone out there done a similar conversion and if so any advise you can offer...
ie where did you get / what make of master cylinder did you use, which is best full or semi hydraulic set up, any problems with mounting the master cylinder to the headset?
roadrunnerian
Hi M8 i have a set up on my mk1 t5 i used a px master cylinder assembly grafted on to my
handle bars, then used a beed speed hub assembly did have a chrome rs scooters one on but
it didn't run true every time i braked it juddered very bad. system i'm using at the moment is perfect well chuffed :D
Mongo
Main scooter: Vespa Rally 200
On my mk1 i've got a remote master cylinder which is mounted in the glovebox to keep the headset looking standard. The hub and disc i used was an LML which I got from Eddie Bullet in Bristol. I liked the LML hub as it looked like the standard T5 hub, but with a disc on the back. You also need to cut a hole in the front mudguard for the brake lines to pass through. The whole set up works really well.
smiffy1968
Main scooter: Nevermind Mk1 T5
I like Mongo, went for the remote master cylinder in the toolbox. Have heard people say these are not very good, although i disagree. I have an auto front wheel complete and if i pull on it, i stop rapidly.
Beedspeed for the remote master, mounted in toolboox and a Lambretta cable adj. block to take the front brake cable.
Jobs a good 'un.
Polossi220
Main scooter: Vespa PX220
Do Mk1 T5 have bolt holes under the headset like a PX ?
if they do I have a bracket to mount a px master cyl to a non disc headset bought but never used ;)
mad-bry
Cheers for the feedback guys, sounds a lot easier than I thought...
Now, any chance of some photos please.. :anbrgin;
roadrunnerian
Hi polossi 220 the brkt had to be welded onto my t5 i used a px brkt and master cylinder and lever looks like it was a orignal job ran the hydraulic line through the headset and forks.
Mongo
If you type in 'Dave Workmans Rally' into the search facility it'll show you some photos of the remote set used on my old rally again mounted in the toolbox. It uses a typhoon master cylinder. It's virtually the same set up on my T5, just a different reservoir. They work a treat in my opinion, and you can still get plenty of spares,oil etc in the toolbox with it. Hope this helps.
Lor@n
On a T5, I went for the full hydraulic version from ScootRS.
Some pics :
http://lambrettiste.free.fr to get a FREE proper timing disc --> http://lambrettiste.free.fr/documents/f ... gradue.pdf
"A tidy shed is a sign of mental disorder"
    Users browsing this forum: Google [Bot] and 15 guests
