Polin 177 kit, revolver exhaust & std.24 mm Dellorto set up
Posted: Tue Jun 05, 2012 9:19 am
by wink
Hi, I am just about to finish the rebuild and I was wondering what the best set up would be for this type of engine.
Can anyone advise on what would be the correct settings for the stator plate/ignition settings (retarded?) and the jetting for the carb.
Thanks In advance,
Re: Polin 177 kit, revolver exhaust & std.24 mm Dellorto set
Posted: Tue Jun 05, 2012 12:28 pm
by hungdog
http://scooterotica.org/forum/viewtopic.php?f=8&t=10869
Follow these tips if your gonna use Si24 carb,timing fully retard, turn stator fully clock wise and see how it goes. 17-18 degrees.
Jetting is 50-120 idle 160/be3/125 main stack, plug check to take it up or down on main.
usual disclaimer WTFDIK :ninja:
