RB250 piston in a TS1
Misunderstood
Main scooter: Italian GP200 (TS1 240)
Hi All,
Might be a stupid question but be gentle with me.
I currently run a TS1 bored to 71mm with a 60mm crank. It's time for the cylinder to be replated & a piston change.
My question is can i rebore to 72mm & use an RB25 Asso piston?
Your comments greatly appreciated.
Thanks.
Steve. :lol:
Muppet
First engineer scotty to kirk; it's borderline on the simulator we need to do more tests if we try it now captain the engines Gunnar blow,
Muppet,
C’est la vie
to take the ts1 to 72 you would need to steel line i think that is if you dont end up with a pile of fins trying to fit a liner
Terrible Taff
Main scooter: Lambretta's & Vespa's
Location: 21 Meyricks, Coed Eva, Cwmbran, Torfaen, NP44 6TU
Misunderstood wrote:Hi All,
Thanks.
Steve. :lol:
Steve I know that Ray @ AF has bored the RB22 from 70.0mm to 72.0mm but has taken about 10mm off the lower section of the skirt so that the spiggot is not too thin.
The core diameters of both cylinders are similar so I see no problem in doing this except for the added cost as a new cylinder head will need to be done as the piston crown angle is shallower!
Best regards
Ian Frankland
Taffspeed
07794 003276
Ian T Frankland
Taffspeed Design Innovations
Mob: 07971 818693
Email: terrible.taff@gmail.com
Misunderstood
Thanks Ian,
That's the answer I was looking for!
You've made my day.
Regards,
Steve. :P
    Users browsing this forum: Ahrefs [Bot], Semrush [Bot] and 9 guests
