Page 1 of 2
Thin ring/quality piston options for standard GP/200dl?
Posted: Sun Jun 03, 2012 12:44 pm
by vegansydney
What are my options for a quality 66.0mm piston with thin rings? Its for a standard GP/200dl so a MBD RaceTour is probably overkill. Looking for something with a full skirt (71mm).
Re: Thin ring/quality piston options for standard GP/200dl?
Posted: Mon Jun 04, 2012 11:00 am
by Muttlyoo7
vegansydney wrote:What are my options for a quality 66.0mm piston with thin rings? Its for a standard GP/200dl so a MBD RaceTour is probably overkill. Looking for something with a full skirt (71mm).
Asso pistons are good and don't break the bank. AF use them in a lot of thier kits.
Posted: Mon Jun 04, 2012 8:28 pm
by mickdale
Muttlyoo7 wrote:vegansydney wrote:What are my options for a quality 66.0mm piston with thin rings? Its for a standard GP/200dl so a MBD RaceTour is probably overkill. Looking for something with a full skirt (71mm).
arent the inlets cut though?
Posted: Mon Jun 04, 2012 8:36 pm
by Muttlyoo7
mickdale wrote:Muttlyoo7 wrote:vegansydney wrote:What are my options for a quality 66.0mm piston with thin rings? Its for a standard GP/200dl so a MBD RaceTour is probably overkill. Looking for something with a full skirt (71mm).
The pistons for piston ported barrels such as the standard iron SIL or the Rapido series aren't cut. However you can have the inlet skirt raised a few mm on request.
Posted: Mon Jun 04, 2012 11:51 pm
by soosh
Does it have to be a thin ring?
Posted: Tue Jun 05, 2012 1:13 am
by vegansydney
soosh wrote:Does it have to be a thin ring?
Preferably, but I will consider other quality options. What do you have in mind? Thanks.
Posted: Tue Jun 05, 2012 9:11 am
by soosh
I've been using a Mahle which was recommended by the person who did my barrel.I run it on the two top rings only.My piston had been modified/cleaned up but yours is std spec anyway so will be fine.My 1st piston covered approx 8k before I replaced as I stripped the motor.It's still a good spare.
Posted: Tue Jun 05, 2012 9:21 am
by goldeneye
same. running a Mahle piston with just the top 2 rings in my cleaned up indian 200 barrel. no problems, runs a 30mm carb and clubman exhaust.
Posted: Tue Jun 05, 2012 10:44 am
by mickdale
soosh wrote:I've been using a Mahle which was recommended by the person who did my barrel.I run it on the two top rings only.My piston had been modified/cleaned up but yours is std spec anyway so will be fine.My 1st piston covered approx 8k before I replaced as I stripped the motor.It's still a good spare.
thanks for the info soosh - 8k cant be bad and they are only 30 quid or so from scooter restorations
Posted: Tue Jun 05, 2012 8:56 pm
by soosh
I'll dig out the clearance that was recommend as there are different grades of piston,I'm sure there was a + size on the std 66mm piston.
