hyd front brake help please
Posted: Thu May 31, 2012 4:58 pm
by oggy
Im getting small drop of fluid at the handle bar end,coming past the piston,its a new speedfight type,the brake is hyd converted sx inboard,ive removed one of the o rings of the disc piston to make it move easier on the disc to relive the pressure at the handle bar end,but still no luck,any ideas????????????
Re: hyd front brake help please
Posted: Thu May 31, 2012 6:39 pm
by nelson pk
A hydraulic brake works on hydraulic pressure so i would have thought removing that seal was a no no.
If you mean your getting a drop of fluid on your handlebar lever most likely cause is the master cylinder seals. Even if its new these can get damaged if someone has been working the lever without any fluid to lubricate in there.
Posted: Thu May 31, 2012 7:52 pm
by col68
have you over filled master cylinder ? i did on my gp
made my nissin master cylinder leek pasts piston when took some out it stopped
Posted: Thu May 31, 2012 9:23 pm
by oggy
will replace the two rubber o rings on the master cylinder,they look ok,how much fluid in the res?,i filled it up to half way,thanks.
Posted: Thu May 31, 2012 9:35 pm
by jason frost
oggy wrote:will replace the two rubber o rings on the master cylinder
Where are the o rings ?
Posted: Thu May 31, 2012 9:57 pm
by oggy
2 of them on the master cylinder piston.
Posted: Thu May 31, 2012 10:06 pm
by jason frost
If the drip is coming from the banjo bolt then try new copper washers first, if the seals have gone then you would not get a drip it would just not work.
Posted: Fri Jun 01, 2012 11:43 am
by oggy
The brake works,the leak is defo comming past the seals as the rubber lever gaitor is wet,will just put up with it,thanks
Posted: Fri Jun 01, 2012 4:37 pm
by jason frost
oggy wrote:The brake works,the leak is defo comming past the seals as the rubber lever gaitor is wet,will just put up with it,thanks
I was thinking of the other end
try a new seal kit you dont want it to fail when you need it.
