nrg 50
Posted: Thu May 31, 2012 2:42 pm
by col68
my son rides an 2007 piaggio nrg power lc 50cc. it has lost some power only running at 37 mph 7000 revs but after 2-3 miles gets better and pulls 48-50 10500 :wtf: is it piston rings or flat rollers . when it slows down will do the same again :wtf: plug colour nice brown. the niple on top of spark plug was loose stayed in cap when i pulled it out made it a bit better when sorted that but its not right :?: :?:
Re: nrg 50
Posted: Thu May 31, 2012 11:48 pm
by Darrell Taylor
sounds like it wants a transmission service start by replacing the rollers and try a fraction lighter say 5.5g or std weights if you decide to replace the rear torque spring a new belt will improve/recover top speed
is it derestricted ?
try closing the plug gap up to 0.5 as the stators fail regularly and this helps to overcome the problem
Re: nrg 50
Posted: Fri Jun 01, 2012 7:48 am
by col68
thanks mate bike is derestricted got a gianelli record pipe and 5.5 gram rollers that came with pipe . fitted a new kevlar belt a year or so ago done about 6000+ miles ta col
Re: nrg 50
Posted: Fri Jun 01, 2012 10:37 am
by Darrell Taylor
try buying a set of 4.5 and 5.5 rollers you can try all 6 as are or mix them giving options of 27g/30g 50/50 mix /33g ,test each set on the road and pick the best result
Re: nrg 50
Posted: Fri Jun 01, 2012 7:42 pm
by col68
thanks for help will order rollers after bank hoilday give it a try :fb:
