Page 1 of 3
burning out clutch plates?
Posted: Tue May 29, 2012 8:00 pm
by servetakid
Ok, I stripped my casings down to inspect why my clutch was playing up. I soon found the clutch corks had burned out. I out it down to an over adjusted clutch cable, there was no play in the lever. I replaced the clutch corks and plates with surflex one along with the springs.
I've been out for a faster run and it started to slip again. Then the cable lost alot of adjustment and the bike started to drag... Got back home and the gearbox oil smelt very burnny like last time. (haven't split the cases yet).
Surely a four plate clutch can survive in a rapido 225 with standard sx 200 gearbox?
Cheers..
Re: burning out clutch plates?
Posted: Tue May 29, 2012 8:12 pm
by joespeed
i keep seeing this problem,mr innocenti realised that the larger front sprocket made the clutch last longer and no need for heavy springs,we are upto three times the origional power of the lambretta,why not follow innocenti's idea and use a gp box with bigger sprockets,
did you soak the plates and check the clearance without the springs?
regards
joe
Posted: Tue May 29, 2012 8:24 pm
by servetakid
I did look at using the GP gearbox, but I couldnt afford it at the time. And I'll be honest I didn't really check clearances as I wasn't sure what i was checking or how... :S
Posted: Tue May 29, 2012 8:43 pm
by joespeed
where are you situated? have you got sticky's book to guide you?
Posted: Tue May 29, 2012 9:00 pm
by servetakid
Cumbria, and yes I have stickys book (the older one). I did follow the instuctions, but I am not 100% sure I checked the clearances right.
Posted: Tue May 29, 2012 9:13 pm
by joespeed
there must be someone close to you who can help,andy francis! could save you time and money!
Posted: Tue May 29, 2012 10:03 pm
by servetakid
Is like to have another go myself, much rather learn myself. I'll have to split the cassings and see what the plates are like. Is there a thread on here which has a step through to show how to set up a clutch properly?
Maybe I should go the whole hog and just buy one of these
http://www.afrayspeed.co.uk/index.php?p ... buteID=CLU
Posted: Tue May 29, 2012 10:15 pm
by psychedelicropcircle
Put PX springs over the lammy ones and Robert is your dads brother.
Posted: Tue May 29, 2012 10:36 pm
by servetakid
Is that an affective way if upgrading your clutch?
Posted: Tue May 29, 2012 10:49 pm
servetakid wrote:Is that an affective way if upgrading your clutch?
It worked for me in an imola 186 which IMO gets the power on before a rapido, and if not you'll be a 5er down.
