early casings with no recess foir oil thrower washer
Posted: Tue May 29, 2012 7:18 pm
hi all
i am doing a engine rebuild for a friend as his casing is cracked.... the casing i have to replace the damaged one is an early one as there is no recess for the oil thrower washer....
do i just rebuild without the washer and adjust rear sprocket to suit or not..???
appreciate all your help thanks
