BGM regulator question
Posted: Mon May 28, 2012 6:24 am
by Robi D
If I'm running a 12V electronic ignition kit in AC, with the BGM regulator, can you just plug into the DC output to power things?
I'd like to stay AC for the rest of the scoot and I'd like to get a gps speedo.
Posted: Mon May 28, 2012 6:32 am
by Dryballs
Yep apparently you can... You might want to run the dc feed to a battery just to smooth the output
I am here:
http://tapatalk.com/map.php?fcq3di
Re: BGM regulator question
Posted: Mon May 28, 2012 6:36 am
by Minority
Robi D wrote:If I'm running a 12V electronic ignition kit in AC, with the BGM regulator, can you just plug into the DC output to power things?
Is it this one?
http://www.bgm-tuning.com/lambretta/ign ... -12v-acdc/
If it is it really depends on what you want to power. If it's a couple of spot lamps (high current) the answer is no - you would have to use the regulator/rectifier to charge a battery. If it's an electronic device eg SIP speedo or GPS speedo (low current) probably yes. Still better to fit a battery, you can get some really small ones these days that are easy to fit in a small space, after all we don't have to power a starter motor on a Lammy.
Posted: Mon May 28, 2012 10:08 am
by Robi D
Yes that's the one. I want to run a speedhut GPS speedo.
Posted: Tue May 29, 2012 12:47 am
by Lamaddict
I've got one it works charging the battery. It pretty neat and not too expensive.
