If I'm running a 12V electronic ignition kit in AC, with the BGM regulator, can you just plug into the DC output to power things?
I'd like to stay AC for the rest of the scoot and I'd like to get a gps speedo.
BGM regulator question
Dryballs
- registered user
- Contact:
Yep apparently you can... You might want to run the dc feed to a battery just to smooth the output
I am here: http://tapatalk.com/map.php?fcq3di
Minority
- registered user
- Main scooter: Li230 S3
- Contact:
Is it this one?Robi D wrote:If I'm running a 12V electronic ignition kit in AC, with the BGM regulator, can you just plug into the DC output to power things?
http://www.bgm-tuning.com/lambretta/ign ... -12v-acdc/
If it is it really depends on what you want to power. If it's a couple of spot lamps (high current) the answer is no - you would have to use the regulator/rectifier to charge a battery. If it's an electronic device eg SIP speedo or GPS speedo (low current) probably yes. Still better to fit a battery, you can get some really small ones these days that are easy to fit in a small space, after all we don't have to power a starter motor on a Lammy.
I've got one it works charging the battery. It pretty neat and not too expensive.
- Information
Who is online
Users browsing this forum: Google [Bot], Google Adsense [Bot] and 3 guests
