Timing or Carb
Posted: Sun May 27, 2012 2:37 pm
I am about to do a 900 mile return journey in two weeks and i cant get my Li to run properly,
its a gp200 barrell on 200 casings with li150 internals. The symptons are real sluggish in first and second and then goes like a scalded cat in 3th and 4th
I recently checked the timing with a strobe i used a dial guage to find tdc and set the timing at 19 deg. I strobed the flywheel and relined the sator till the arrow on the flywheel corresponded with the 19 deg mark btdc. I ignored the with line on the black box and the two notches on the flywheel, was this the correct way of doing it.
The carb i am using is a Dellorto 26mm PHBH, not sure what the jetting is but i had it running on a Honda 205 and it ran great.
I am hoping its just a matter of down jetting the carb but was just wondering could the timing be an issue, could there be any other things i need to look at.
Thanks in advance.
Thanks in advance.
