Rust Converter
Posted: Sat May 26, 2012 3:30 pm
A little while ago I was speculating about the use of these products on rusted areas of metal. Well; I finally got around to giving it a go and I think you'll agree the results are remarkable.
Firstly take one rusted mudguard.
Lightly rub down. The trick here is not to remove all the rust so that the converter has something to key too.
I had intended to do a small portion of the mudguard so that it would be possible to see the bare and treated metal. But to be honest the effects were immediate and so I did the lot. I was quite surprised at how quickly the reaction took place.
So there you have it. I feel the results will vary according to the surface being treated. But, it does work. It dried quickly and it will probably only need a bit of flatting to apply paint directly to it. That's the next step.
