SIP TUBELESS WITH Schwalbe RACEMAN Question
Posted: Fri May 25, 2012 8:27 pm
by philhnottm
Just fitted a set of these to a P2 Disc
Space between rear tyre and RH JL is very very tight. Is This normal ???
Gather i dont need extra spacers , washers etc They seem bigger tyres thanthe Coni's that i took off.
Also is it worth putting Puncture Gel inside like i did in my old tubes???
Any advice welcome
Thanks
Phil
Re: SIP TUBELESS WITH Schwalbe RACEMAN Question
Posted: Sun May 27, 2012 6:01 pm
by tomdavid1988
Hi Phil, it is normal for there to be very little space between tyre and JL exhaust, I wouldn't pack it out with washers as it starts putting stress on the exhaust.
I don't bother with the goo in mine, but I suppose it is good practice.
Posted: Sun May 27, 2012 7:43 pm
by fraserp200e
Keep an eye on your rear shock as well. My schwalbe raceman tyres were rubbing - especially when it's loaded with gear - I ended up putting a wee spacer washer between the hub and the wheel for a bit of extra clearance. Mine were split rims though, not tubeless.
Posted: Mon May 28, 2012 11:16 am
by MCH
the racemans have a wider tyre wall than most other tyres, you will find they look a lot wider too because of this, even though the tread pattern will be the correct width as stated on the tyre,
Posted: Tue May 29, 2012 8:28 pm
by gimp1971
i had trouble with racemans with my scorpion they rubbed so got rid of it and put a taffy on that worked also hiedenhau spelt wrong i know are thinner
Posted: Tue May 29, 2012 8:58 pm
by philhnottm
Thanks to all
Made a big difference , now fitted to all scooters.
Regards
Phil
Tom ( all rims and hubs spot on thanks to all at WSP)
