IMOLA exhaust opitons?
Posted: Fri May 25, 2012 8:21 pm
Im running a Silver special with an imola kit & 28mm dellorto.
Im not interested in expansion pipes, just options for a standard looking pipe to fix with the imola kit.
I opted for the Ancilotti pipe when i fitted the kit late last August, after dropping the engine today and removing the exhaust i discovered the fin ( 2x m8 stud fastenings) on top of the box has cracked almost the full length along the seam/join, with one of the loops / holes you put over the sutds totally crumbled in half...
Adding to this the fact the manifold has cracked all around the stub, leaving 1/3 or less of the diameter remaining intact and holding it all together haha, wow.
After being very impressed with the build quality and craftsmanship i may just buy another one... however i wondered what else was out there worth considering.
cheers
cheers
