clutch problems?
Posted: Thu May 24, 2012 8:55 pm
Ok, I am having some clutch problems on my jet200. It's a four plate clutch with updated springs in a rapido classic 225, nk road pipe and a 30mm phbh.
I went out for a run last night, one of the longest I've been out for and I opened her up a bit too. Then the clutch started slip, revs pick up but the bike didn't get any faster. At one point I could even open the throttle past about 1/5 open.
Tonight, my dad adjusted the cables and went out for a run. No sign of any slipping. But now when you start it and go into gear it'll jolt and stall as if it is dragging. And if you adjust the cables the kick start will become soft and not engage.
So I guess I'm going to have to split the casings? What should I look out for and check?
Cheers,
Cheers,
