Lost all lights and horn....... Help!
Posted: Mon May 21, 2012 6:57 pm
Started up my non-battery p200e and noticed the headlight was flickering. I whipped off the left hand side panel to have a wee look at my voltage regulator and sure enough one of the spade connector had sheared (the one the yellow wire connects to).
The yellow wire was sparking and arcing to the regulator so I disconnected it, and in the process lost all my lights and indicators and horn. When I got home I tried to connect the wire again but when I did I still had no lights etc. scooter still runs fine.
The scooter is a Spanish import and doesn't have the standard regulator (mine is about an inch square and half an inch deep with two spades connectors coming out the front, one for the yellow wire and one for the two green wires connected together, the regulator body earths to the frame where you bolt it on). I tried a standard regulator on tonight and still got no lights.
My question is what voltage should I be getting at the input (?) yellow wire at the regulator? Or I am barking up the wrong tree?
Any ideas??
Any ideas??
