ball park for main jet ?
gaz_powell
what kit and carb ?
gaz_powell
cast or ali ? mazz race or standard ?
would start at 130 and come down
might want to up the pilot as well 55/160 is standard at 2.9
52/140= 2.7 richer or 60/160 = 2.6 richer
depnding on the kit be careful on the clearance they are often a bit tight - would check it out and go 4 thou clearance
set timing at px125 mark on the stator 17-18 degrees
have seen some of the ali kits were the liner is out and the ports need work to tidy up and bring the timings in line
best of luck and keep us posted
