Page 1 of 2
Clinder head gasket sealent
Posted: Thu Apr 09, 2009 6:45 pm
by celt
Does anyone recommend a good cyl gasket sealant?
I have a skimmed and lapped head, I've used a small smear of Hylomar universal blue in the past but have run out.
Is there a decent alternative?
Re: Clinder head gasket sealent
Posted: Thu Apr 09, 2009 6:53 pm
by shocky
i use normal clear silicone
Posted: Thu Apr 09, 2009 8:14 pm
by Ihateyoubutler
Thanks Shocky, I was about to ask the same question.
Posted: Thu Apr 09, 2009 9:14 pm
by cezeta
shocky wrote:i use normal clear silicone
so do british bike builders to stop them leaking, b and q
Posted: Thu Apr 09, 2009 11:14 pm
by RobD
Yambond or Hondabond. Available on ebay branded as threebond from memory.
Posted: Thu Apr 09, 2009 11:15 pm
by RobD
An impossible task on most british bikes :lol:
Posted: Fri Apr 10, 2009 12:47 am
by coaster
Ditto 8-)
Posted: Fri Apr 10, 2009 7:56 pm
by Stringy
Stag Wellseal is good. :)
Posted: Fri Apr 10, 2009 9:19 pm
by J1MS
Ive used locktite for the last twenty plus years, before that I used to use gaskets that had a habbit of going pop if the Scooter was ridden too hard....Started using it after I ran a Yamaha DT175 piston with high comp head, the Locktite was reccommended by Dave Webster.....who was I to argue.... :shock:
Posted: Fri Apr 10, 2009 11:57 pm
by sideout
Is Blue Hylomar recommended? :?
