Advice on minor nip up.
Posted: Thu Apr 09, 2009 1:21 pm
I had a couple of nip ups the other day, was riding along and just sensed something was wrong, pulled the clutch in and it died straight away. I coasted to a standstill put it on the stand and it started first kick and tickover was fine. Pulled over a bit further and checked the plug which seemed ok. Carried on and it happened again exactly the same symptoms and result so I just limped home taking it easy. The scooter starts fine and ticksover ok. I thought I better check it out and this is what I found. Any answers to the following questions would be really appreciated.
Any idea what may have caused this?
I think the piston crown and inside of head look fine am I right? If so can I assume that this has not been caused by a timing issue and that my timing is somewhere near correct?
The barrell seems ok with no gouges and the rings are free on the piston. Will I be able to clean the piston up and re-use, if so how do I clean up the piston and rings? (Idiots guide please)
It is a 175 barrell on a 150 casing, any idea what sort of piston this is, as can been seen it is only 2 ring and has 6222 GPM on the inside.
Cheers.
Also,
It's a 150 barrell bored to 175 and I'd been told it had been run in but not 100% sure especially as there is a lack of carbon build up on the crown and cylinder head. Would the timing appear to be ok?
Set up is:
150 bored to 175
42mm Clubman
MA19BS5 with following jetting
Main 108
Atomiser 260B
Pilot 40
Slide 50
Starter 55
6.5 gm float
Airscrew 1/2 turn out
Plug Nippon Denso W24 Es
Speed when nipped up about 40 to 45.
Thanks.
[/img]
[/img]
Cheers.
Also,
Set up is:
150 bored to 175
42mm Clubman
Main 108
Atomiser 260B
Pilot 40
Slide 50
Starter 55
6.5 gm float
Thanks.
