Page 1 of 2
WTF evaporating oil ?
Posted: Mon May 14, 2012 10:59 pm
by carlos fandango
I rebuilt my engine a couple of months ago, just new bearings and seals.
Almost immediately it kept jumping out of 2nd gear, which was odd because it didnt do it before, anyway i tightened the cables and this cured it, with it only doing it when really accelerating hard. So today i thought id get the side of and check the Gearbox and selector. when i drained the oil there was only about 150ml
Now i know i filled the gear box up with a 500 ml of rock st90 and toped it up from a second bottle?
No noticeable oil leak ?
And no smelly black smoke ?
Any ideas ?? ive only done less than 300 miles since the rebuild ?
Looks like the crank will have to come out and change the drive side bearing and oil seal again
The clutch bush is worn quite a bit so ill probably have to change all the rest of the bearings as well
Re: WTF evaporating oil ?
Posted: Tue May 15, 2012 6:36 am
by Toddy
carlos fandango wrote:I rebuilt my engine a couple of months ago, just new bearings and seals.
Daft question Russ are both Level and Drain plugs tight ? Have you taken the Hub off ? any oil in there??
If Not Eden will have syphoned it off while you were asleep
Posted: Tue May 15, 2012 7:37 am
by carlos fandango
Lol it stands a chance
The hub and drain plugs are ok ?
Posted: Tue May 15, 2012 8:46 am
by Supereibar
Russ, that happened to me with a Chubby Checker crank.. erm.. a MECeur race crank that I had on a GP200 engine. When using it, I wouldn't smell a thing, nothing, but the engine would still drink up the casing oil right away. I would nottice that I had no oil at about 500kms so yes, more or less the same distance as you. Oddly enough mine used to jump out of 1st gear going uphill with a lady riding pillion :biggrin:
Posted: Tue May 15, 2012 9:53 am
by Toddy
carlos fandango wrote:Lol it stands a chance
One of our lads had a dodgy casing side plug which didnt seat correctly and lost oil , rear hub was wondering if seal had gone or Bearing spinning in casing mate
Posted: Tue May 15, 2012 12:48 pm
by dave wheeler
my gp would stand all winter without so much as a drop on the floor but a 250 mile thrash was enough to loose half the chaincase capacity, ive now fitted a 1mm thick chaincase gasket as it seemed that the chaincase seal was fine when cold but a combination of thinner (hot) oil and heat expanding the gap in the chaincase was enough to loose oil
Posted: Tue May 15, 2012 10:07 pm
by carlos fandango
We'll got the crank out and the oil seal looks fine it, was a double lip one, I've changed it anyway.
So I'm still scratching my head ?
There are only three reasons for the lack of oil that I can think of ...
1. Operator error, i.e. not putting it in in the first place. I'm Deffo I did , as the empty oil bottle is still I'm my bench, and as id just rebuilt it there would be no oil in what so ever.
2.leaking externally from a gasket , oil seal or crack... No signed of an oil leak ?
3 leaking internally. Drive side oil seal, or possibly rear hub. . Again no signs of oil any where or oil seal damage , the only thing I've found is a bit shaved of the layshaft O ring but no signs of oil around the brake area ?
Oh well , I'll put it back together. It's just another thing to worth about ! Lol
Posted: Tue May 15, 2012 10:22 pm
by Toddy
Posted: Wed May 16, 2012 12:06 am
by cezeta
there is a fourth, twisted crank will let the oil through a good seal
Posted: Wed May 16, 2012 12:03 pm
by carlos fandango
cezeta wrote:there is a fourth, twisted crank will let the oil through a good seal
Hmmm I hadn't thought of that.
I did check the crank after I rebuilt it, but the bodgers method with a screwdriver in the end of the crank, and all seemed fine
