Page 1 of 3
TS1 gearbox help
Posted: Fri May 11, 2012 10:13 am
by woody
Hi, i,m running a ts1 225 with a msc micron exhaust and a 34mil amal powerjet carb , which gearbox and sprocket will give me the best results i,ve got the choice of an italian LI150 box or an SX200 box , thanks
Re: TS1 gearbox help
Posted: Fri May 11, 2012 11:19 am
by soosh
I used to run that setup although mine is only a 200 but used the LI box 16-46 but you can use the SX box with 15-46. Both give 4.8. Or use the LI box with std sprockets but it will probably be undergeared.
Posted: Fri May 18, 2012 12:43 pm
by woody
Anybody else any ideas please ?
Posted: Fri May 18, 2012 12:55 pm
by JINX
Have you tried the gearbox visualizer spreadsheet?
I am using Li150 and 16/47, 81 link chain, for a 4.99 4th gear ratio.
In the end though, it depends on your type of riding, speed versus quickness, lower end torque/how high your rpms want to be at what speeds.
Posted: Mon May 21, 2012 9:16 am
by woody
JINX wrote:Have you tried the gearbox visualizer spreadsheet?
No i havn,t its all dutch to me that technical stuff , i just want to go at a decent sped on runs etc without revving the knackers off it and still be able to go up hills, or into a wind etc without dropping into 3rd all the time been recommended to put in a indian gp200 box and 19t sprocket but thats confused me even further !
Posted: Mon May 21, 2012 10:04 am
by Muttley McLadd
Is your barrel modded at all?
I ran a similar set up a few years ago. 34 mil Amal and a DJ/Micron. I ran 4.6 on it, and it was fine for high speed cruising. It did have a bit of mild porting though.
Posted: Mon May 21, 2012 10:26 am
by Dryballs
woody wrote:JINX wrote:Have you tried the gearbox visualizer spreadsheet?
That would give you the same final gearing as your SX box with standard sprockets or the Li150 box with 16/46
Dont bother getting another gearbox!
I would go for the Li with 16/46 and get one of those over the top chain tensioners and 81 link chain. Then if you want more speed you can put a 17 tooth front sprocket in without buying more bits
That help?
Posted: Tue May 22, 2012 8:15 am
by woody
Dryballs wrote:woody wrote:JINX wrote:Have you tried the gearbox visualizer spreadsheet?
That help?
shouldn,t have to bother bother about buying another gearbox as i,ve a couple of spare types , so not bothered about that but i,m gonna wip off the crankcase side and count what sprockets i,ve got in cheers
Posted: Tue May 22, 2012 8:16 am
by woody
Muttley McLadd wrote:Is your barrel modded at all?
yes pal mine has been slightly tuned by ralph saxelby ,nothing too serious though
Posted: Tue May 22, 2012 11:34 am
by soosh
Then 4.8 with the LI box will be fine. He did a bit of work to mine when I had it running with the Micron.
