Jimmers manifold...?
Posted: Mon May 07, 2012 8:42 pm
Just put together scoot (rb20) after doing some bodywork and added a jimmers manifold and a new fuel hose. Scoots all back together and starts okay and runs okay but after approx 300 meters it just dies, this happens at exactly the same distance every time?. Have to wait a a minute or so and it starts fine only to die again after 300 meters......again. It feels like a fuel problem but I cant get to the bottom of it. so far we have repaced the carb with an exact same one with same jetting set up from a scotter that runs fine and the still have the same problem, so know its not the carb. Have taken hose off of carb to test flow rate which is spot on. Isolated the ignition, augusto, changed cdi, reg, made sure the hose isnt being crushed by bump stop. Oh and also changed the fuel just in case..
The barrel is now off and will be measured to see if the piston to bore gap is okay but to be honest i think its fine just from a visual inspection so i dont think its barrel wear. Looked at the reeds which again are fine. Im not really sure where to go from here. I cant see how a slightly different manifold would cause this (jetting ?) or a new fuel hose but i will change the hose and go back to the old AF manifold and see if that cures it. could it be a stator issue, getting to hot maybe, we havent looked at this as the symptoms dont really point to this being the problem.
If anyone has any ideas would be mauch appreciated, iv already lost this bank holiday and southends on the horizon...
Ta
Sef
Ta
Sef
