JL stub
Posted: Thu May 03, 2012 11:13 pm
I've just acquired a JL, looking at the stub, for standard port, without the gasket in there's a 3mm or so gap and the sleeve touches the fins.
With the gasket in it looks like there's about 1mm of clearance from the fins, but that's not tightened down. I think if I tighten it the sleeve will touch / jam on the fins.
Is this normal? Do I need to grind the fins a little?
