Page 1 of 2
Speed Sensor Fitting
Posted: Thu May 03, 2012 8:53 pm
by fsmlittler
Anyone got any photos of how they've fitted speed sensors for digital speedos?
Also should the magnet be fitted so that it attracts the sensor or repulses?
Re: Speed Sensor Fitting
Posted: Thu May 03, 2012 10:43 pm
by Craig H
Craig H wrote:A bit more progress had the speedo sender bracket welded to speedo housing.
Posted: Thu May 03, 2012 11:25 pm
by fsmlittler
That looks superb but I was really interested to see anyone who'd used a more basic bracket?
Still curious about the magnet?
Posted: Fri May 04, 2012 7:03 am
by Craig H
Some senders need the north of the magnet facing towards them to work and some need the south
Posted: Fri May 04, 2012 7:13 pm
by jackpot
fsmlittler wrote:That looks superb but I was really interested to see anyone who'd used a more basic bracket?
when jason frost first did mine he put the magnet in the worm drive inside the hub and the cable into the hub through the existing speedo drive
Posted: Fri May 04, 2012 7:45 pm
by carlos fandango
Heres mine fitted it last week. and still covered in some northern french mud
ive just put two magnets on by the disk bolts, i put a blob of loctite just to make sure they didnt fly off
Posted: Fri May 04, 2012 11:58 pm
by fsmlittler
Thanks all. Looks like I'll finally have to get a disc fitted up front. Don't suppose anyone out there has fitted one to a drum set up using a simple bracket?
Also any idea on the magnet question - attracting or repulsing?
Posted: Sat May 05, 2012 8:59 am
by twenty eight
fsmlittler wrote:Thanks all. Looks like I'll finally have to get a disc fitted up front. Don't suppose anyone out there has fitted one to a drum set up using a simple bracket?
I had my vapour speed sensor mounted on my disc caliper bracket,i have since fitted a mb bracket that fits on the hub spindle you then put your magnet on the hub you can fit this without a disc brake hope this helps
Posted: Sat May 05, 2012 7:47 pm
by sideout
twenty eight wrote:
Excellent way to attract people. My congratulations to Photobucket.
Posted: Sat May 05, 2012 7:54 pm
by fsmlittler
So how do I get to see the photobucket picture?
