electrics li special
Posted: Tue May 01, 2012 9:01 pm
by chez
got a strange problem with electrics hope one of the resident wizards can help, start scooter no lights position 1 on key, position 2 side lights and speedo light works, position 3 main lights no speedo illumination, had look at stickys book diagrams show black wire from switch joins black wire from speedo bulb and black from loom same as mine stumped as to why light goes out any ideas much appreciated cheers chez
Re: electrics li special
Posted: Thu May 03, 2012 9:06 pm
by chez
Posted: Fri May 04, 2012 9:04 am
by Dimitrios_231
What is your problem?
You don't have speedo light at position 3?
Posted: Fri May 04, 2012 11:02 am
by WINTERMODEL150
[quote="chez"]got a strange problem with electrics hope one of the resident wizards can help, start scooter no lights position 1 on key, position 2 side lights and speedo light works, position 3 main lights no speedo illumination, had look at stickys book diagrams show black wire from switch joins black wire from speedo bulb and black from loom same as mine stumped as to why light goes out any ideas much appreciated cheers chez
[/quote
Follow the black wire from the tail light up into the handlebars and then join the speedo black wire to this (best way to describe it if electrics aren't your thing )
Dean
Posted: Fri May 04, 2012 10:30 pm
by chez
thanks wintermodel150 your comment made me think, maybe black wire not constant from rear light and fault could be at rubber covered junction box will investigate further cheers.
dimitrios_231 yes the problem is driving in the dark with no speedo as position three is main lights.
thanks
