ball park jetting
Posted: Tue May 01, 2012 11:00 am
by tea5ive
i need some info to get my carb in the right ball park.
here is the set up
rapido 240 reed valve
60mm stroke crank /standard rod
li 150 gear box 17/46 ?
standard indain stator with wassel conversion/ semi light flywheel
dev-tour exhaust
carb is a vhsh 30mm
i need to know main,idle,choke,slide,needle and atomizer and float valve.
cheers simon
Re: ball park jetting
Posted: Tue May 01, 2012 2:05 pm
by gaz_powell
rayspeeds jetting table states the following for a TS1 225 using a VHSH:-
150 main
DP 266
U16
50 slide
60 with b40 pilot
60 choke
2.5-3.5 turns out (out to richen)
shouldbe a reasonable start
