Vapor Trailtech Speedo Stopped Working
Posted: Mon Apr 30, 2012 3:38 pm
by Bilko
My Trailtech has developed an issue regarding the speedo. The Milometer and Speedo have stopped, but everything else works.
Magnet is fine, as is the gap. Wires all in place. Joints were sealed with Amalgamating tape.
Anyone know something else I could have missed or should be checking?
Thanks.
EDIT: Just to add. The display used to shut off to just the clock after 20 mins, but now it doesn't. Although the display light does stop.
Posted: Mon Apr 30, 2012 4:36 pm
by jonashford
Is the magnet and sensor still intact? If they are left aligned the unit doesn't turn off
Re: Vapor Trailtech Speedo Stopped Working
Posted: Mon Apr 30, 2012 5:22 pm
by twenty eight
From the above it looks like you have (or did not)have it connected up to a power source it will turn off after 20 mins it was just running off the units battery,if you have lost your magnet or the sensor has come loose you will have a 0 showing, try unpluging it and re connecting it if this does not work on the back of the unit is a red reset button try that if no good it looks lake a new speed sensor cable,hope this helps Rob
Posted: Mon Apr 30, 2012 6:34 pm
by Bilko
Thanks.
Reset & reconnected at the headset. Still nowt.
I'll reconnect from the sensor cable end tomorrow and see if that makes any difference.
Thanks again.
EDIT: There's only one connection. MB out of stock too. Titfuckcunt.
Posted: Tue May 01, 2012 6:38 am
by Toddy
Bilko wrote:Thanks.
Thanks again.
Is it a faulty Battery in the unit ??
Posted: Tue May 01, 2012 7:03 am
by rbgaz
hi bilko, my vapour speedo has also stoped working , every thing else is fine revs,temp etc which is a shame cause it was good bit kit mines about two years old i hav checked magnet wireing etc and can see no fault so im thinking the speedo cable wants renewing but im not sure if they even make these units anymore ? i can still do my speed on the rev counter, if u find a sorce for the speedo cable let us know cheers
Posted: Tue May 01, 2012 8:03 am
by twenty eight
found this on e-pay 21 pounds 260778136347 cheers
Posted: Tue May 01, 2012 8:18 am
by Toddy
Posted: Tue May 01, 2012 10:13 am
by Bilko
Gaz, I think mine's still in Warrenty so I'll contact MB. If not, then I might try the sensor from eBay (Cheers 28)
Toddy. Their sensors are out of stock.
If my speedo is f@@ked, would those black trailtechs work? I like the look of those.
Posted: Sun May 20, 2012 12:09 pm
by Bilko
Just an update.
I bought a new sensor of ebay and it was the sensor that was dead. So I'm delighted to have my Trailtech back.
