Page 1 of 2
rapido/reedvalve advice
Posted: Sat Apr 28, 2012 4:34 pm
by tea5ive
Re: rapido/reedvalve advice
Posted: Sat Apr 28, 2012 4:50 pm
by Stampede
Wouldn´t change anything, looks pretty good.
Posted: Sat Apr 28, 2012 4:59 pm
by chris2470
Of course it will run, but better off selling the TS1 piston, get a Avanti or 1mm Asso & cut in the windows to match the inlet.
Posted: Sat Apr 28, 2012 5:09 pm
by tea5ive
chris2470 wrote:Of course it will run, but better off selling the TS1 piston, get a Avanti or 1mm Asso & cut in the windows to match the inlet.
why sell the ts1 piston ? it allready has window cut in.
Posted: Sat Apr 28, 2012 5:42 pm
by RICSPEED
i guess the question is what position in the piston travel do the pics shown relate to ? as we have no way of knowing if the holes are in the correct place
Posted: Sat Apr 28, 2012 5:43 pm
by RICSPEED
i notice no rod in third pic
Posted: Sat Apr 28, 2012 5:56 pm
by tea5ive
RICSPEED wrote:i guess the question is what position in the piston travel do the pics shown relate to ? as we have no way of knowing if the holes are in the correct place
yes ric, should have added the first 2 pics are with the piston at bdc and the bottom pic is with the piston at tdc.
i can now add that i will also be using a vhsh carb and the head is a new type af 9-5-1 ratio.
Posted: Sat Apr 28, 2012 5:58 pm
by Darrell Taylor
looks ok ,the ts1 piston windows dont line up to the rapido inlet left and right but no real loss
are you doing extra transfer/transfers with the reed?
Posted: Sat Apr 28, 2012 6:01 pm
by tea5ive
Darrell Taylor wrote:looks ok ,the ts1 piston windows dont line up to the rapido inlet left and right but no real loss
would like to do a bit more, but this would be beyound my tuning skills
Posted: Sat Apr 28, 2012 6:03 pm
by coaster
I used a TS1 piston in my Indial Ally 225 reed valve conversion and the windows lined up fine. Not as good as the Racetout that it replaced as that had larger squared windows but it worked ok. You could do with cutting a boost port while you're at it to help it breath better and compensate for the restriction to the inlet caused by the reeds.
