Page 1 of 2
What do you thick ???
Posted: Fri Apr 27, 2012 7:25 pm
by Tosh
Not started scoot for a couple of month due to jobs needed doing around house,gave it a shake,choke,
petrol 3rd kick away it went,then it stopped went to kick it wouldn`t go down solid thought it had locked up,put into 3rd i could shove it ?? then it started with a kick(and not a size 10 dockmartin)
but there seams to be a funny noise say like a bearing so i stopped it and now its on the bench
mystified to say the least
Re: What do you thick ???
Posted: Fri Apr 27, 2012 7:39 pm
by Hopey
my mate had a similar thing happen on the way to kelso a few years ago, stopped at a petrol station , filled up, and couldnt kick it over after. his locked the back wheel up tho. the problem was his gearbox endplate bearing had collapsed and one of the balls had jammed the gearbox, we tried bumpstarting it and took a couple of teeth off his 2nd gear Doh !!!!
hope this helps. id strip it down and have a look if i were you
Posted: Fri Apr 27, 2012 8:30 pm
by Tosh
ta hopey for that,well iv`e got a full bearing set for a 150 case iv`e been thinking of building suppose i`ll have to use some of those if needed
Posted: Wed May 02, 2012 7:51 am
by Tosh
well striped engine down,clutch,gears,end plate,checked shims all ok for tolerances,so before i go into the top to check up there as anybody go any idea`s PRETTY PLEASE,also there seems to be a slight wearing sound coming from the fly wheel side
but i suppose that could transmit to any part of the engine
Posted: Wed May 02, 2012 8:16 am
by Darrell Taylor
might be a stator plate bolt thats dropped out ,worth popping the flywheel off first
Posted: Wed May 02, 2012 8:58 am
by Tosh
thanks darrell will have a look tnight all being well and will let you know
Posted: Wed May 02, 2012 4:57 pm
by Yanker
Yeah. Have a look at the flywheel. I had similar symptoms and after going through the transmission, found that it was one of the pins that hold the magnets in the flywheel had drifted out and was gouging into the mag flange....
Posted: Wed May 02, 2012 6:04 pm
by GP240
Magnet come away from flywheel and wedged into stator,
or, check the kick-start plunger and see if the two teeth are still there. One of mine broke off and found it's way to second gear (sudden lock-up of back wheel whilst accelerating).
Posted: Thu May 03, 2012 12:38 am
by coaster
Had similar issue on the way to last years Euro in Ireland. Stopped in Travelodge on M6 overnight, Started fine in the morning and tootled round the services to put some ait in the rear tyre only to find that the engine locked up when I tried to kick it. Gave it a bump but without success. Removed the flywheel to find that the pickup screw had come out and wrecked most of the coils on my stator
Luckily I had a spare :fb:
Posted: Sat May 05, 2012 9:57 pm
by Tosh
well the update, totally stripped casing only barrel left,what have we here,exhaust off head off very slight pitting of head on exhaust side and top of piston,took barrel off bottom ring fell into 5 bloody bits
peg missing from piston
and also exhaust port chipped top and bottom on 1 side
but rest of barrel ok but there was still a slight grinding noise when i moved the crank up an down
took crank out to find a piece of piston ring bedded into the casing below the crank,managed to get it out and rubbed down with 1200grade so thats ok,now if i can get a picky onto the forum hopefully some kind person might tell me whats the best option.
