when starting
Posted: Tue Apr 24, 2012 8:46 pm
by djh66
the lammy, cold, with choke on, it bursts into life first kick, but it burbles and if I open the throttle it dies. It will rev normally after 30 seconds. Any ideas? too big pilot?
cheers
Re: when starting
Posted: Tue Apr 24, 2012 10:32 pm
by bristolmod
Crystal balls a bit iffy at the moment I'm afraid........................
Engine spec; carb; jetting etc please.............
Re: when starting
Posted: Tue Apr 24, 2012 11:06 pm
by djh66
bristolmod wrote:Crystal balls a bit iffy at the moment I'm afraid........................
GT186 24MM PWK BREATHING THROUGH RAM, GJH NEEDLE (MIDDLE CLIP), 118 MAIN, K34 PILOT
Re: when starting
Posted: Wed Apr 25, 2012 9:14 am
by Rich_T
If it revs alright after 30 seconds it isn't the idle just it is most probably the choke jet size but either way what you are describing is completely normal for a cold start on a choke, even my NC30's do it.
As a word of advice for all Lambretta engines, I wouldn't advocate gunning any engine from a cold start until it had ticked over for a bit and at least got some warmth into it.
Re: when starting
Posted: Wed Apr 25, 2012 6:06 pm
by djh66
Other than that, RichT, the GT kit is running great, still got to get a few more miles on the clock to run it in, but I will mail you my final carb spec. when all run in.
Dave
Re: when starting
Posted: Thu Apr 26, 2012 9:25 am
by Rich_T
many thanks, I'll keep a note and update the manuals with the information when it comes.
