Indian 22mm Carbs
Posted: Sun Apr 22, 2012 12:25 am
by Lamaddict
Just got a secondhand 22mm Indian Jetex carb, it has a 118 main jet in. I was wondering if there's any difference between the 150 and 200 22mm ones like there was on the Dellortos, slides/jetting etc? I've also heard of some mods that need doing on the Jetex to make it perform properly?
Re: Indian 22mm Carbs
Posted: Sun Apr 22, 2012 1:04 am
by Supereibar
Slide and atoimizers are different, as far as I know, that is the main difference.
Posted: Sun Apr 22, 2012 11:21 am
by Doom Patrol
I've heard of people modding a Jetex carb, but I've no idea how. I think they are unfairly maligned really. Replace the jets with proper Dell'orto ones and they are usually very good. What I will say though is that the paper gasket for the bowl is absolute rubbish and the main weakness if you ask me. It's not a carb for chopping and changing your jetting because the gasket will just go to pieces and leak fuel everywhere.
Posted: Sun Apr 22, 2012 8:04 pm
by Lamaddict
I'll try and use some Dellorto 18/20 mm choke and pilot jets. Can anyone tell me if the Dellorto 18/20 had similar jets to the Dellorto 22?
Posted: Sun Apr 22, 2012 10:12 pm
by Doom Patrol
Not on your nelly. Before you start you need to tell us what carb you've got and what engine it's going on. Is there a bowl cut into the back of the slide? If so it's a 150 carb.
Posted: Sun Apr 22, 2012 10:34 pm
by Lamaddict
Only going on standard 200 with a standard exhaust. No cut out on the slide, I thought some of the Dellorto jets might have be easy to swap?
Posted: Sun Apr 22, 2012 11:02 pm
by rosscla
The jets might be easy to swap but getting the right ones is the trick ;-)
Posted: Sun Apr 22, 2012 11:11 pm
by Doom Patrol
A 45 or 48 pilot, atomiser 5899.2, probably a 120 / 122,3 main jet with a 50 choke I would think should put you in the ball park. But there is only one way to find out.
