Kickstart pinch bolts.
Posted: Fri Apr 20, 2012 11:12 am
by Ihateyoubutler
Anyone know where I can get some proper high tensile kickstart bolts (c/w nuts) from? Stainless ones might as well be made of cheese.
Thanks.
Re: Kickstart pinch bolts.
Posted: Fri Apr 20, 2012 1:04 pm
by Supereibar
Hello, the main problem is that pinchbolts are M7. What I would do is I would try at an industrial hardware store. Take your lever with you so you can test the length with a vernier caliper. Ask the clerk which surely will be very helpful and show you the different variety. Here in town we have one which has a huge catalogue. The problem is that these bolts are mostly made with an allen head.
Kind regards,
J.
Posted: Fri Apr 20, 2012 1:58 pm
by warts
http://www.boltmeup.com/m7-x-50-hex-hea ... 2421-p.asp
Just a specimen size, they have other lengths if this not suitable
Posted: Fri Apr 20, 2012 2:54 pm
by RICSPEED
is there not a fastener supplier near to you ?? also many drill out to m8
Posted: Fri Apr 20, 2012 7:41 pm
by camel
websters sandycroft or drb deeside industrial park
Posted: Fri Apr 20, 2012 7:43 pm
by rosscla
I'm very suspicious of stainless fasteners after shearing one of the rear hub bearing retaining plate ones recently with the torque wrench set at 5NM...
Posted: Fri Apr 20, 2012 8:18 pm
by soulsurfer
Loads on eBay
