Rear hub
Posted: Tue Apr 07, 2009 1:31 pm
Just come down to work on me scoot. On my way down I could hear a flapping noise
from the back end. Upon checking I found all wheel nuts had become loose and the rim was about to come off. (Mb hub with press in studs already fitted by them and bought last year)
one of the studs spins in the hub now although its supposed to be presed in!
I know this has happened to a lot of people in the past but im posting this just to let you all know that even when you fit what you think is the best it is still wise to check the scoot over before going out on it!!
Its done about 60 miles this year and nylock nuts had been fitted and tightened correctly!!
im just glad I didn't come off at speed !! So even if you have fitted the best please check regularly as I wouldn't want anyone else coming a croper this way!!
