Build advice please?
Posted: Tue Apr 17, 2012 11:12 pm
Am finally getting my act together and getting my motor built.
It's a 225 rapido classic, avanti piston with 58/107 crank AF 9.5 - 1 head.
I've tried a couple of ways to take the measurements to work out what the timings are, but. I'm not that sure I'm getting it right....
I put the degree disk on and set 0 as tdc and took the following measurements
Exhaust opens 90 ATDC
Exhaust closes 269 ATDC
Giving a duration of 179
Transfers open 113 ATDC
Transfers close 244 ATDC
Giving a duration of 131
Inlet opens 69 BTDC
Inlet closes 77 ATDC
Giving a duration of 146
I make the exhaust 34.93mm from the top of the cylinder and the transfers 44.3. I have a deck height of 1mm with a 0.55mm base gasket.
I hacked those figures into the port timing calculator and got -
Exhaust 176.33
Transfers 135.99
Inlet 139.27
Q1. Do these figures seem about right ? Which are closer?
Q2. When it comes to setting the squish if I use a 0.7 mm Head gasket then I'll have 1.7 squish which is probably too big. If I take the base gasket out then I'll get back to about 1.25. Will this make much of a difference or how do I deal with this?
Inlet opens 69 BTDC
Exhaust 176.33
Transfers 135.99
Inlet 139.27
