Clutch Spiders
Posted: Sun Apr 15, 2012 6:17 pm
by ferritt
I've taken my clutch to bits today as it was slipping badly, amongst other things the clutch spider is knackered. Is the SIL item that scooter restorations sell a direct replacement ( jet 200 ), only asking because mb state on their website that the fingers are longer and may require a shim somewhere??? Has anyone any experience of the SIL item, did it fit ok etc, thanks.
Re: Clutch Spiders
Posted: Sun Apr 15, 2012 9:20 pm
by wack 63
The SIL one should go straight in but check the clearance when fitted to the crownwheel,ie how much it protrudes through. Personally I don't use Indian spiders as they have a tendancy to wear on the legs, it's better to use a Innocenti or Spanish original .
Re: Clutch Spiders
Posted: Sun Apr 15, 2012 10:33 pm
by sydduckett
My indian one decided to break one of the legs and throw a 10mm bit into the gears on the way to iow acouple of years ago, brown pants time...I now use the £70 italian ones... ;)
Re: Clutch Spiders
Posted: Mon Apr 16, 2012 7:48 pm
by ferritt
Thank for the information fellas
