New piston & barrel, now won't tick over...
Posted: Sun Apr 15, 2012 4:47 pm
by a.j
200cc 66.8 rebore, 20mm dellorto carb, ran fine until I went next size up on the piston. Revs fine but no matter how much I've adjusted the carb it will not tick over. Any pointers?
Re: New piston & barrel, now won't tick over...
Posted: Sun Apr 15, 2012 5:18 pm
by bristolmod
1) Air leak- base; top or either manifold
2) piston upside down
3) blocked jet in carb
4) cable adjustment wrong
5) slide stop vs air screw out of adjustment
6) tight top end- bore to piston clearance?
7) piston wrong height on inlet side??
8) new barrel? port timings way out?
Posted: Sun Apr 15, 2012 5:38 pm
by a.j
It's not piston upside down or gaskets. Never moved adjustable nipple for throttle cable to carb. Not new barrel. Gonna try other options though cheers .
