Can I use a rd 350 reed block fitted straight in to the TS1
Posted: Fri Apr 13, 2012 3:37 pm
by boxofbits
Can I use an rd 350 reed block fitted straight in to the TS1 with a 5mm packer with the original AF read manifold what about clearance
Also it seems to have metal reeds petals- these any good !
I have an MB manifold but the packer doesn't match up right ( i can see daylight in one corner)
Re: Can I use a rd 350 reed block fitted straight in to the
Posted: Fri Apr 13, 2012 6:42 pm
by rocho68
boxofbits wrote:Can I use an rd 350 reed block fitted straight in to the TS1 with a 5mm packer with the original AF read manifold what about clearance
no they have to be machined , i have one that i brought for a project and is complete if i get my money back back that i paid for it then its available , pm me if your intrested ;)
Posted: Fri Apr 13, 2012 8:10 pm
by Diablo
The metal reeds are s**t. invest in some Boyson ones. 2 stage if you can afford it.
Posted: Fri Apr 13, 2012 8:53 pm
by rocho68
Diablo wrote:The metal reeds are s**t. invest in some Boyson ones. 2 stage if you can afford it.
the ones ive got are also the boysen 2 stage reeds ... :D
