Sprint rack for slope back seats
soosh
Who sells these racks or is it anyone?
Ta :)
Rich Presley has a couple
DaveTomo
Main scooter: SX 200
I've got one of these off Andy Francis if you don't want the offset type that fits to the normal sprint rack hole this one fits on the back 2 and then the rear legs fit behind the number plate http://www.ekmpowershop12.com/ekmps/sho ... 1615-p.asp you can fit quite a bit on it,but saying that I am using panniers with it this year as doing a lot more camping than B&B'ing.Also to my mind if you want to put a bit on it these are more sturdy as you have the rear legs to support the weight,where as the off set type all the weight is on the 2 back bolts,but I suppose its down to personal preference.
GP Kevo
KB Paintshop made mine back in the day (circa 2001).
soosh
Cheers chaps,im sure ive also seen some adapted to fit on the front mudgaurd too.
soosh wrote:Cheers chaps,im sure ive also seen some adapted to fit on the front mudgaurd too.
http://www.chasspeedfabs.co.uk/racks.htm ;)
Soosh.. it'll look a heap cleaner if you ditch the rack altogether.
Is this for your GP range? Are you painting it? Fill the holes.. Looks much better with a slope back seat.
