rear brake light
Posted: Mon Apr 09, 2012 4:42 pm
by gpsteve
i have just done the lights on my lambretta cut down all the lights are working but can not get brake light to work its got a front brake light wire ,and rear foot brake light wire can any body help
Re: rear brake light
Posted: Mon Apr 09, 2012 5:26 pm
by dodge
try disconnecting front wire then put 12 volt tester on connector on foot brake to make shore you have voltage if so check switch
Posted: Mon Apr 09, 2012 6:45 pm
by gpsteve
thanks for the help dodge problem sorted it was front brake wires the lad that i got it of used heat shrink to cover the both wires so both the wires were touching each other :biggrin:
