S2 & S3 Frame Differences?
Posted: Sun Apr 08, 2012 8:20 pm
by soulsurfer
What are the geometric differences between a S2 and S3 frame with regards to engine/expansion pipe fitting that warrant different rear shock lengths and specific expansion pipes? Why is this?
Re: S2 & S3 Frame Differences?
Posted: Sun Apr 08, 2012 11:08 pm
by RICSPEED
the actual tube frame is the same ...series 1 / 2 sat higher ..hence the longer shock and different links ..pipe is just due to the body work
Posted: Mon Apr 09, 2012 7:03 am
by soulsurfer
RICSPEED wrote:the actual tube frame is the same ...series 1 / 2 sat higher ..hence the longer shock and different links ..pipe is just due to the body work
Cheers Ric.
So the top shock mount is higher, and fork links are different? Would S3 shock and links cause any issue on a S2?
Apart from the obvious what are the bodywork issues that affect the pipe fitment?
Posted: Mon Apr 09, 2012 11:22 am
by RICSPEED
the shock mount is same for all li series .. series 3 stuff on series 2 should be fine ..issues only arise with reed clearance
the rear runner mount although in the same position as s3 its just the amount of metal that extends back from the fixing point in comparison to s3 runners that causes clearance issues
Posted: Mon Apr 09, 2012 6:47 pm
by Supereibar
Shocky, from Cheltenham, forward some pictures to me showing the differences in fork links. The fork links sit in a different angle between SII and SIII, as to cope with the higher frame difference. However, this doesn't matter that much I guess since TV175 series II's in Spain had SIII engines and SIII disc brake fork links.
J.
Posted: Mon Apr 09, 2012 6:54 pm
by soulsurfer
Great, so I should be able to shoehorn a SM in then
Posted: Mon Apr 09, 2012 8:58 pm
by RICSPEED
soulsurfer wrote:Great, so I should be able to shoehorn a SM in then
absolutely .. you will need to trim the rear board for the pipe .. or if you are creative with the welder ..
Posted: Tue Apr 10, 2012 2:31 pm
by matthew
TJ's got a SM currently going in his series 2 spineframe and Charley's making him a pipe specifically for the S2 frameset to ensure there's no clearance issues.
Posted: Tue Apr 10, 2012 4:02 pm
by soulsurfer
matthew wrote:soulsurfer wrote:Great, so I should be able to shoehorn a SM in then
Excellent, cheers Matt
I should've asked Charlie in the first place I guess
