Expansion Pipe with good ground clearence?
Posted: Sun Apr 08, 2012 7:32 pm
Hi All,
I'm after some advice if possible?
I fitted the latest version of the mugello small block 198 kit to my LI over the winter, I matched the inlet, exhaust and casings and have had it on the dyno at Readspeed a few weeks ago where it produced 20bhp and decent torque using an AF NK road pipe which I was quite happy with.
I'm suffering from ground clearence issues with the AF pipe which has similar routing to the Chiselspeed ADS3, particularly on left hand corners or when two up (which is rare) it grouds out.
I could modify the stub manifold to gain 10mm or so of clearence but am thinking that a different exhaust like the Chiselspeed ADS5, Franspeed Race or JL4 would work better as the routing is much less complicated, or perhaps just put a good clubman back on, Gori race?
Has anyone had any experience with these exhausts or could recomend an exhaust suitable for my mugello with good ground clearence? I'm using a 300mm R1 shock, uprated fork springs and only weigh 12 stone so can rule those out, but do ride motorbikes a lot so am possibly a bit quick to lean the Lambretta over
Jonny
Jonny
