30mm phbh dellorto jetting help for ts1
Posted: Sun Apr 08, 2012 10:56 am
by col68
Help needed jetting my ts1 225 standard tune 60 stroke crank jl3 pipe augusto 6000 30mm phbh with fillter av268, x7 , 3rd cilp up, 142 main, 55 pilot, 40 slide. runs clean no stutter but cant get any colour on plug light tan at 1/2 throttle about 5000 revs . not tryed 3/4 or full yet. i have got x13 and x2 to what do you think ?? :wtf: have been thinking about fitting a tmx 35.!! thanks col
Re: 30mm phbh dellorto jetting help for ts1
Posted: Mon Apr 09, 2012 10:54 pm
by Diablo
Try the X2 needle top clip or the x13 2nd clip. That should richen things up part throttle.
As you richen the mid range you often get a cough about 4-5000rpm. Be careful not to weaken too much to get rid of it because on the dyno the fuel graph is usually bang on either side. A bell mouth sometimes helps if you have a hole in the panel. You can get filters that will still fit a bellmouth on the carb as well.
142 main is huge 130-135 is more usual
Posted: Tue Apr 10, 2012 8:05 pm
by col68
Been out tonight with x13 ended up on top notch still not alot of colour . 3rd notch splutering at half throtle started to clean up at 1/2- 3/4 . do you think timing could be out ? what would you have it set at between 6000-7000 ? :wtf: ta col
Posted: Thu May 31, 2012 7:54 pm
by col68
sorted now exhaust gasket leek
